Configure a UDP port forward entry to add or remove a port forward entry.
  1. Enter either Global Configuration mode or VRF Router Configuration mode for a specific VRF context:
    enable
    configure terminal
    Optional: router vrf WORD<1-16>
  2. Configure a UDP port forward entry:
    ip forward-protocol udp portfwd <1–65535> {A.B.C.D}
  3. Confirm your configuration:
    show ip forward-protocol udp portfwd [vrf WORD<1-16>] [vrfids WORD<0-512>]
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#ip forward-protocol udp portfwd 150 192.0.2.10
Variable definitions
Use the data in the following table to use the ip forward-protocol udp portfwd command.
Variable
Value
<1-65535> {A.B.C.D}
Adds a UDP protocol port to the specified port forwarding list.
1-65535 is a UDP protocol port in the range of 1–65535.
A.B.C.D is an IP address in a.b.c.d format.
Use the no operator to remove a protocol port forwarding entry and IP address from the list: no ip forward-protocol udp portfwd <1-65535> <A.B.C.D>.
To configure this option to the default value, use the default operator with this command.
vrf WORD<1-16>
Specifies the name of the VRF.
vrfids WORD<0-512>
Specifies the ID of the VRF.
